Re: HP 50G List of Library numbers already in use? Message #2 Posted by Joe Horn on 4 Aug 2013, 11:09 a.m., in response to message #1 by Michael Lopez
> Just wondering if there is a list anywhere of the Library numbers that are already widely in use on the HP 50G & even HP 48 series? Also, what is the permitted range of library numbers to use?
Rules for HP 48/49/50 library ID numbers in HEX:
0000 - 0100 Take-over libraries; do not use
0101 - 0300 HP ROM-based libraries; do not use
0301 - 05A0 Assigned by HP to 3rd Parties
05A1 - 0600 For your experimental work; not kept track of by HP
0601 - 06F6 For personal non-shared use
06F7 - 06FF Already allocated by HP; do not use
0700 - 07FF Command-line; do not use
The rules as originally published by HP can be found here:
http://www.hpcalc.org/hp48/docs/programming/libnums.txt
Here are two lists of ID numbers in use by libraries published until 2009:
HP48: http://www.hpcalc.org/details.php?id=4532
HP49: http://www.hpcalc.org/details.php?id=4533
Hope that helps!
-Joe-
