Re: WP-34S: # constant in exponent Message #3 Posted by Dieter on 6 July 2013, 1:20 p.m., in response to message #1 by Marcel Samek
Marcel,
the #nnn shortcut enters an integer and quits digit entry before and after the command. Thus it cannot be combined with regular digit entry. So the sequence...
1
EEX
#123
...does not return 1E123. Instead, it enters two different values: "1 EEX" equals 1 and #123 is, well, 123. So you will end up with 1 in Y and 123 in X. That's the way it is supposed to work. And it is consistent, since you cannot use...
1
#234
...to enter 1234 either. Or even think of this one:
#123
#456
Of course this will not produce a six-digit integer like 123456. ;-)
By the way, your example can simply be coded as
#001
SDR nn
That's even shorter.
Dieter
