HP 67 problems Message #1 Posted by Manel on 11 June 2013, 5:33 p.m.
Hello
I bought a HP 67 and after a quick test, I opened it to repair then gum card reader. Once assembled everything I encounter two problems:
1 - The reader does not work, it does not take the card when I insert it. I tried to connect the motor directly to the battery and it works. I have also checked the circuit and it is closed when I start inserting the card. What is it wrong ? Maybe is the chip damaged ?
2 - When I switch to program mode, nothing changes. I also tested the continuity of the tracks and it seems ok ... How can I fix it ?
Thank you very much in advance
Manel
Edited: 11 June 2013, 5:40 p.m.
