HP Forum Archive 21
WP-34S Bug Report
Message #1 Posted by Barry Mead on 11 June 2013, 12:48 a.m.
Last week I bought a WP-34S calculator from Eric Rechlin and I am generally very pleased with the advanced technology incorporated into this device. I did, however, discover one small bug that I wish to report. The "Complex Hyperbolic Tangent" function does not follow the rules described in the manual of using RADIANS exclusively.
When the calculator is in the DEGREES or GRADS mode, the Complex Hyperbolic Tangent function (and none of the other complex trig functions) erroneously performs a conversion of the imaginary component into RADIANS (from DEGREES or GRADS depending on the mode) before performing the calculation. If the calculator is actually in the RADIANS mode then the Complex Hyperbolic Tangent function performs as expected. Example: With 3 in the X register and 4 in the Y register (representing the complex number 3 + i4 ) with the calculator in DEGREES mode the Complex Hyperbolic Tangent function returns a result of 0.99510252637 (real) 0.00068657645 (imag). The correct answer is: 1.00070953607 (real) 0.00490825807 (imag)
My actual calculator has a VERS string "34S3.2T3382" and I also confirmed that the emulator with Version 3.2 SVN 3402 exhibits the same behavior, so I believe the bug has not been fixed yet.
Re: WP-34S Bug Report
Message #2 Posted by Paul Dale on 11 June 2013, 1:18 a.m.,
in response to message #1 by Barry Mead
Yes, a bug. A fix has been committed. A build will come later, I can't access the build machine at present.
- Pauli
Message #3 Posted by Marcus von Cube, Germany on 11 June 2013, 4:43 p.m.,
in response to message #2 by Paul Dale
Windows is a mess... ;(
After an hour or so of updating the build system I was finally able to do a rebuild of the WP 34S software. It's available on SVN.
Message #4 Posted by Barry Mead on 11 June 2013, 9:51 p.m.,
in response to message #3 by Marcus von Cube, Germany
I tried a bunch of svn clone commands that I found on various web pages related to the wp-34s, but none of them seem to work.
Can you quote me the EXACT svn clone command needed to retrieve the binary flash files I need to update my wp34s so that it will no-longer have the "Complex Hyperbolic Tangent" bug?
Message #5 Posted by Marcus von Cube, Germany on 12 June 2013, 3:58 a.m.,
in response to message #4 by Barry Mead
The following should do:
svn checkout svn://svn.code.sf.net/p/wp34s/code wp34s
It will download the complete tree.
If you just want to get to the binaries try this in your browser:
http://sourceforge.net/p/wp34s/code/HEAD/tree/trunk/realbuild/
