WP-34s feature suggestion: "Follow jump" shortcut Message #1 Posted by Andrew Nikitin on 10 June 2013, 7:08 p.m.
I would like to suggest a "follow the jump" keyboard shoutcut in sto mode.
If
current command shows GTO, XEQ, BACK or SKIP, this shortcut should just take
you there according to standard label search algorithm. Indirect jumps could be
ignored, or they could use current value of a register. Even cooler: if you
follow XEQ this way, then save the address in special stack and "follow"
shortcut applied to RTN (or RTN+1) takes you back (or back-er). (you only need
to keep this special stack while in sto mode, dispose it when exit).
I nominate
[->][->] for a shortcut.
Edited: 10 June 2013, 7:08 p.m.
