WP-34s negative shifts Message #1 Posted by Andrew Nikitin on 10 June 2013, 5:47 p.m.
Currently when r00=-3, SDL[->] 00 multiplies rX by 1000, I think it should
handle this case and divide it by thousand. As in "negative shift left is shift
right". Same for SDR.
I would also argue that ASR,SL,SR,RL,RLC,RR,RRC should handle negative numbers
whenever selected sub-mode implements negative numbers.
