Re: WP-34s manual Message #5 Posted by Andrew Nikitin on 27 May 2013, 3:19 p.m., in response to message #3 by Walter B
Walter, I understand that reformatting the manual is not trivial and requires effort. That is why I volunteered.
As far as printed edition goes, it too may benefit from smaller format. After all, one of calculator's strong point is its portability. Shouldn't the manual be portable too? For example, I have an HP35s manual, which is half letter size, and HP50g manual, that I had to print on a letter paper from PDFs and bind at local Staples. I claim that there is noticeable difference in convenience. HP50g's is quite unwieldy and cumbersome to read and HP-35s's is comfortable.
If you remain unconvinced, I still respect your decision to stay with A4. In this case I would like to do a reformatting just for my own personal use. I promise not to distribute the source or modified version (in case this is your concern).
(I saw you mention Kindle edition in later post. I do not own Kindle, is it going to be in some proprietary formats that only Kindle can read?)
