Re: HP charger 82002c for handheld calculators Message #2 Posted by Gerson W. Barbosa on 19 May 2013, 1:57 a.m., in response to message #1 by Dave Burson
This has a 3 pin output and meters a nominal 5 VDC between center and right pin and nominal -17 VDC from center to left pin. The 5 volt side makes sense but is the other voltage an indication of a bad circuit?
Please take a look at HP Battery Information, in this museum.
Quoting from the linked page:
"The battery charger circuit is current limited and will typically read much higher than 4.2 V without a load."
HTH
Gerson
P.S.:
Classic Charger Schematic
Edited: 19 May 2013, 2:14 a.m.
