Re: HP-Prime photo Message #6 Posted by bhtooefr on 18 May 2013, 8:00 a.m., in response to message #5 by Steve Simpkin
As I understand, there's an RPN mode, but here's what we don't know:
- We don't know how deep the stack is
- We don't know how integrated the stack will be with everything else - for instance, if I want to run a program, will I have to run the program as Progname(Arg1,Arg2,Arg3), or do I put Arg1, Arg2, and Arg3 on the stack and run Progname like on an RPL machine?
- We don't know how similar to RPL it is re: objects being on the stack (but, given that the 39gII does support objects in its "algebraic stack" (which does behave like an RPL machine in algebraic mode, IIRC), I'd guess that it is fairly similar in that regard, but I think programs will be their own different thing, and the CAS/numeric split will cause some behavior changes there, too, I think)
- For that matter, we don't even know for sure if it's Entry RPN or behaves like Classical RPN as far as number entry goes (but I'd be highly surprised if it were Classical)
