Fun things found by running strings on the 39gII emulator Message #1 Posted by bhtooefr on 11 May 2013, 1:02 p.m.
It looks like none of this actually works, but...
D$,RPN
D$ WRPN
Probably just a coincidence, I mean, there's other stuff that looks like that and has other characters that appear to mean nothing.
RPN loop
Boucle en mode RPN
Um... what... (This is in what appears to be a list of commands with their associated English and French descriptions, and there's no actual associated command here, it seems (although I need to look closer.))
rpn()
RPN mode (Reversed Polish Mode)
Mode RPN (saisie polonaise inverse)
Well then. (However, that command is taken as a syntax error.)
T_STACK
T_RPN_END
T_RPN_BEGIN
T_RPN_OP
T_RPN_WHILE
T_RPN_IF
ROLL
ROLLD
SWAP
OVER
PICK
DROP
RPN_LOCAL
RPN_FOR
RPN_WHILE
RPN_CASE
RPN_UNTIL
rpn_prog
RPN_LOCAL
RPN_LOCAL must have at least 3 args
STEP
NEXT
START
Invalid_RPN_FOR
RPN_FOR must have at least 4 args
REPEAT
Invalid_RPN_WHILE
WHILE
RPN_WHILE must have at least 2 args
CASE
Invalid_RPN_CASE
RPN_CASE must have at least 1 arg
UNTIL
Invalid_RPN_UNTIL
RPN_UNTIL must have at least 2 args
RPN-specific looping constructs, as well as an RPN-specific local variable assignment? Very, very interesting.
Edit: Not as interesting as I thought. They just left Giac's rpn.cc in. (Funnily enough, they also left Giac's ti89.cc in. That's right, there's code for simulating TI-89 behavior in the 39gII, that's just sitting there doing nothing.)
Edited: 11 May 2013, 1:52 p.m.
