Re: Catalogs as menus in WP34s Qt Emulator Message #5 Posted by fhub on 8 May 2013, 7:20 p.m., in response to message #1 by pascal_meheut
WOW, that's really a great feature, many thanks!
It's also good that the textsize can be changed in the skinfile because it was set a bit too big for my taste.
But there are 2 things I would like to change (that's why I looked at the skinfiles if it can be done):
What I don't like very much is that this popup windows overlaps the calculator - I would prefer a separate window docked at the left side of the calculator window (in the same way as the debugger/register window on the right side).
And then this command list should only have the same heigth/length as the main (calculator) window, but not the full screen height - possibly with a scrollbar like the register display.
Of course that's only _my_ opinion ...
And then it would be great if we could also have such a window for alpha-characters, because entering special characters is quite complicated in the WP34s. I know that this would be much harder than displaying the catalog commands (because this alpha-mode is structured in a different way), but maybe you could find a method!? ;-)
Franz
