Update of Emu28 to v1.27 Message #1 Posted by Christoph Giesselink on 30 Apr 2013, 3:03 p.m.
Emu28 v1.27 is available at http://hp.giesselink.com.
Changes to v1.26:
- changed "Locale" KML command (in difference to Emu42 the Locale now reference to the keyboard layout and not to the keyboard input locale any more, this allows now i.e German-German as keyboard input locale but a Swiss keyboard layout)
- native sound support (true emulation) over the OUT=C opcode
- removed PC speaker support
- switched default CPU strobe frequency to 640 kHz
- minor "Find" additions in the debugger "Code" and "Memory" window
Emu28 v1.26 has a bug in "Authentic Calculator Speed" mode. The 1LK7 CPU is emulated with a strobe frequency of 1 MHz, but correct is a nominal speed of 640 kHz. To fix this you may delete the registy key "HKCU\Software\Emu28\Emulator\SaturnCycles" or save this code snippet as file patch28.reg:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Emu28\Emulator]
"SaturnCycles"=dword:00000027
and execute this registry file with a double click and confirm the popping up messages.
To activate the sound emulation you must remove all ROM beep patches in your KML files please. If you normally download only the binary package, you should download the 28C KML file as well. The actual KML file package don't have the ROM beep patches and also has an updated set of keyboard scancode include files.
Dependant when you created the HP-28C state file you have to perform a warmstart <ON>+<SK3> on the simulated calculator to initialize the CSPEED calculator RAM variable to a reasonable clock speed value. For more information you may have a look inside the Emu28 manual section "8.6.3 Sound section" please.
Christoph
