Re: New HP 39gII firmware Message #7 Posted by fhub on 26 Apr 2013, 11:51 a.m., in response to message #6 by Mic
Yes, just the HP39gII.exe
If you see new features, tell us :)
Well, the only new 'feature' I see is that this version now is asking for a '10 character keycode'! Of course I don't have such a code, because the 39gII emulator never needed any code in the past. So I can't use it right now ...
But I've cracked all other HP emulators, so I'm sure it will also be no problem for this 'update' - it just needs a bit work.
Franz
Edit: Problem with the keycode solved - was quite easy (just a single-byte-patch). ;-)
Let me know if anyone needs this 'medicine' for the new HP-39gII update ...
Edited: 26 Apr 2013, 3:16 p.m.
