Re: Matrices on HP39gii (Cautionary Tale) Message #3 Posted by Gilles Carpentier on 23 Mar 2013, 7:54 p.m., in response to message #2 by Patrice
I second you about this behavior.
A new firmware is needed...
here a small program for "sprites" ...
Works fine and quick but ... I crashed my calc with it. So be carefull and backup the 39GII memory ( Copy your sources in another place that the connectivity kit because all is lost in a bad crash !!)
EXPORT Sprite(Pause)
IF Pause==0 THEN Pause:=.00001 END;
L1:={ 0,0, 0,1, 1,0, 9,0, 10,0, 10,1, 0,9, 0,10, 1,10, 10,10, 10,9, 9,10, 2,3, 2,5, 3,2, 3,4, 4,1, 4,3, 5,2};
DIMGROB_P(G1,13,13,0); RECT_P(G1,0,0,12,12,3,0);
FOR I FROM 1 TO SIZE(L1) STEP 2 DO
PIXOFF_P(G1,L1(I)+1,L1(I+1)+1);
RECT_P(0,0,255,126,0,3); X:=100;Y:=100;
REPEAT
X:=MIN(241,ABS(X+ISKEYDOWN(10)-ISKEYDOWN(14)));
Y:=MIN(112,ABS(Y+ISKEYDOWN(15)-ISKEYDOWN(9)));
BLIT_P(X+1,Y+1,G1); WAIT(Pause);
UNTIL 0;
Usage
Sprite(0.01) //0 is max speed
To exit ON/C
Small video on an adapted version
Snake II alpha
Edited: 24 Mar 2013, 6:07 a.m.
