Re: No luck getting flash disk to work in 95lx Message #6 Posted by BobVA on 17 Mar 2013, 6:35 p.m., in response to message #1 by Harald
As I recall, the 95 has a V1.0 slot and the only "approved" memory solution was a SRAM (not flash) card. Upshot was that even with the Sundisk driver it was a bit finicky about cards, but I'm even hazier as to the "why?".
I *believe* the issue was that V2.0 expected a 12v supply on the PCMICA connector and the 95 didn't supply this. Consequently, it could *read* a generic V2.0 card, but not write to it. I think Sundisk made V2.0 cards which could be written at 5v, and you had to use one of those in the 95.
Ring a bell with anyone? I used to know this stuff :-)
Bob
Edited: 17 Mar 2013, 6:39 p.m.
