Re: Music for the HP-71B? Message #7 Posted by Gerson W. Barbosa on 14 Mar 2013, 11:33 p.m., in response to message #1 by Christoph Giesselink
I've converted the following from an HP-48 program ( http://www.hpcalc.org/details.php?id=2561 ). I've tested it on Emu71 1.03 and a few notes on the real HP-71B. This wouldn't have won the Best Music Oscar either :-)
10 COMPLEX A
15 READ A
20 N=REPT(A) @ D=IMPT(A)
25 IF D=0 THEN END ELSE IF N=0 THEN WAIT D ELSE BEEP N,D
30 GOTO 15
40 DATA (261.626,.273), (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545)
41 DATA (261.626,.273), (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545)
42 DATA (261.626,.273), (246.942,.239), (0,.034), (246.942,.273), (261.626,2.182)
43 DATA (195.998,.545), (130.813,.545), (233.082,1.909), (0,.273), (261.626,.273)
44 DATA (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273)
45 DATA (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273)
46 DATA (246.942,.239), (0,.034), (246.942,.273), (261.626,.273), (293.665,.239)
47 DATA (0,.034), (293.665,2.182), (349.228,.239), (0,.034), (349.228,2.182)
48 DATA (329.628,.273), (261.626,.273), (293.665,2.182), (195.998,.239), (0,.034)
49 DATA (195.998,.273), (329.628,.273), (261.626,.273), (293.665,2.182), (391.995,.273)
50 DATA (261.626,.273), (349.228,2.182), (329.628,.239), (0,.034), (329.628,2.182)
51 DATA (293.665,.239), (0,.034), (293.665,1.909), (0,.273), (261.626,.273)
52 DATA (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273)
53 DATA (246.942,.273), (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273)
54 DATA (246.942,.239), (0,.034), (246.942,.273), (261.626,2.182), (195.998,.545)
55 DATA (130.813,.545), (233.082,1.909), (0,.273), (261.626,.273), (246.942,.273)
56 DATA (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273), (246.942,.273)
57 DATA (261.626,.545), (195.998,.545), (174.614,.545), (261.626,.273), (246.942,.239)
58 DATA (0,.034), (246.942,.273), (261.626,.273), (293.665,.239), (0,.034)
59 DATA (293.665,2.182), (349.228,.239), (0,.034), (349.228,2.182), (329.628,.273)
60 DATA (261.626,.273), (293.665,2.182), (195.998,.239), (0,.034), (195.998,.273)
61 DATA (329.628,.273), (261.626,.273), (293.665,2.182), (391.995,.273), (261.626,.273)
62 DATA (349.228,2.182), (329.628,.239), (0,.034), (329.628,2.182), (293.665,.239)
63 DATA (0,.034), (293.665,2.182), (261.626,.273), (261.626,.273), (261.626,.273)
64 DATA (246.942,.273), (261.626,1.909), (0,.273), (261.626,.273), (246.942,.273)
65 DATA (261.626,1.909), (0,.273), (261.626,.273), (246.942,.273), (261.626,2.182)
66 DATA (293.665,.239), (0,.034), (293.665,2.182), (349.228,.239), (0,.034)
67 DATA (349.228,2.182), (329.628,.273), (261.626,.273), (293.665,2.182), (195.998,.239)
68 DATA (0,.034), (195.998,.273), (329.628,.273), (261.626,.273), (293.665,2.182)
69 DATA (391.995,.273), (261.626,.273), (349.228,2.182), (329.628,.239), (0,.034)
70 DATA (329.628,2.182), (293.665,.239), (0,.034), (293.665,2.182), (329.628,.273)
71 DATA (261.626,.273), (293.665,2.182), (195.998,.239), (0,.034), (195.998,.273)
72 DATA (329.628,.273), (261.626,.273), (293.665,2.182), (391.995,.286), (261.626,.286)
73 DATA (349.228,2.286), (329.628,.263), (0,.038), (329.628,2.474), (293.665,.276)
74 DATA (0,.039), (293.665,2.609), (261.626,.292), (0,.042), (261.626,.302), (0,.043)
75 DATA (523.251,.3), (493.883,.3), (523.251,.545), (391.995,.545), (349.228,.545)
76 DATA (523.251,.273), (493.883,.273), (523.251,.545), (391.995,.545), (349.228,.545)
77 DATA (523.251,.273), (493.883,.239), (0,.034), (493.883,.273), (523.251,2.182)
78 DATA (391.995,.545), (261.626,.545), (466.164,1.909), (0,.273), (523.251,.273)
79 DATA (493.883,.273), (523.251,.545), (391.995,.545), (349.228,.545), (523.251,.273)
80 DATA (493.883,.273), (523.251,.545), (391.995,.545), (349.228,.545), (523.251,.273)
81 DATA (493.883,.239), (0,.034), (493.883,.273), (523.251,.273), (391.995,.273)
82 DATA (369.994,.273), (391.995,.273), (698.456,.273), (659.255,.273), (698.456,2.182)
83 DATA (523.251,.273), (493.883,.239), (0,.034), (493.883,.273), (523.251,.273)
84 DATA (391.995,.273), (369.994,.273), (391.995,.273), (698.456,.273), (659.255,.273)
85 DATA (587.33,.273), (587.33,2.182), (523.251,.239), (0,.034), (523.251,.205)
86 DATA (0,.068), (0,1.636), (0,.545), (0,.205), (0,.068), (0,1.636), (0,.545), (0,0)
Better eliminate lines 10 and 20 and all parentheses and edit line 15 to READ N,D to avoid the need of the MATH ROM
P.S.: This is half the size and doesn't require the MATH ROM:
20 READ N,D @ IF N<>0 THEN BEEP N,D ELSE IF D<>0 THEN WAIT D ELSE END
30 GOTO 20
40 DATA 262, .273, 247, .273, 262, .545, 196, .545, 175, .545
41 DATA 262, .273, 247, .273, 262, .545, 196, .545, 175, .545
42 DATA 262, .273, 247, .239, 0, .034, 247, .273, 262, 2.182
43 DATA 196, .545, 131, .545, 233, 1.909, 0, .273, 262, .273
44 DATA 247, .273, 262, .545, 196, .545, 175, .545, 262, .273
45 DATA 247, .273, 262, .545, 196, .545, 175, .545, 262, .273
46 DATA 247, .239, 0, .034, 247, .273, 262, .273, 294, .239
47 DATA 0, .034, 294, 2.182, 349, .239, 0, .034, 349, 2.182
48 DATA 330, .273, 262, .273, 294, 2.182, 196, .239, 0, .034
49 DATA 196, .273, 330, .273, 262, .273, 294, 2.182, 392, .273
50 DATA 262, .273, 349, 2.182, 330, .239, 0, .034, 330, 2.182
51 DATA 294, .239, 0, .034, 294, 1.909, 0, .273, 262, .273
52 DATA 247, .273, 262, .545, 196, .545, 175, .545, 262, .273
53 DATA 247, .273, 262, .545, 196, .545, 175, .545, 262, .273
54 DATA 247, .239, 0, .034, 247, .273, 262, 2.182, 196, .545
55 DATA 131, .545, 233, 1.909, 0, .273, 262, .273, 247, .273
56 DATA 262, .545, 196, .545, 175, .545, 262, .273, 247, .273
57 DATA 262, .545, 196, .545, 175, .545, 262, .273, 247, .239
58 DATA 0, .034, 247, .273, 262, .273, 294, .239, 0, .034
59 DATA 294, 2.182, 349, .239, 0, .034, 349, 2.182, 330, .273
60 DATA 262, .273, 294, 2.182, 196, .239, 0, .034, 196, .273
61 DATA 330, .273, 262, .273, 294, 2.182, 392, .273, 262, .273
62 DATA 349, 2.182, 330, .239, 0, .034, 330, 2.182, 294, .239
63 DATA 0, .034, 294, 2.182, 262, .273, 262, .273, 262, .273
64 DATA 247, .273, 262, 1.909, 0, .273, 262, .273, 247, .273
65 DATA 262, 1.909, 0, .273, 262, .273, 247, .273, 262, 2.182
66 DATA 294, .239, 0, .034, 294, 2.182, 349, .239, 0, .034
67 DATA 349, 2.182, 330, .273, 262, .273, 294, 2.182, 196, .239
68 DATA 0, .034, 196, .273, 330, .273, 262, .273, 294, 2.182
69 DATA 392, .273, 262, .273, 349, 2.182, 330, .239, 0, .034
70 DATA 330, 2.182, 294, .239, 0, .034, 294, 2.182, 330, .273
71 DATA 262, .273, 294, 2.182, 196, .239, 0, .034, 196, .273
72 DATA 330, .273, 262, .273, 294, 2.182, 392, .286, 262, .286
73 DATA 349, 2.286, 330, .263, 0, .038, 330, 2.474, 294, .276
74 DATA 0, .039, 294, 2.609, 262, .292, 0, .042, 262, .302, 0, .043
75 DATA 523, .3, 494, .3, 523, .545, 392, .545, 349, .545
76 DATA 523, .273, 494, .273, 523, .545, 392, .545, 349, .545
77 DATA 523, .273, 494, .239, 0, .034, 494, .273, 523, 2.182
78 DATA 392, .545, 262, .545, 466, 1.909, 0, .273, 523, .273
79 DATA 494, .273, 523, .545, 392, .545, 349, .545, 523, .273
80 DATA 494, .273, 523, .545, 392, .545, 349, .545, 523, .273
81 DATA 494, .239, 0, .034, 494, .273, 523, .273, 392, .273
82 DATA 367, .273, 392, .273, 698, .273, 659, .273, 698, 2.182
83 DATA 523, .273, 494, .239, 0, .034, 494, .273, 523, .273
84 DATA 392, .273, 367, .273, 392, .273, 698, .273, 659, .273
85 DATA 587, .273, 587, 2.182, 523, .239, 0, .034, 523, .205
86 DATA 0, .068, 0, 1.636, 0, .545, 0, .205, 0, .068, 0, 1.636, 0, .545, 0, 0
For some reason the macro player (set to manual, fastest) skipped this comma, which I had to insert manually:
Speaker sounds better than Wave on my notebook. The choice of the music has nothing to do with what I think of the HP-71B :-)
Surely a great pocket computer, well ahead of its time!
Edited: 15 Mar 2013, 2:07 p.m.
