Re: Authentic HP85 color? Message #3 Posted by inaki on 11 Mar 2013, 4:58 p.m., in response to message #2 by Diego Diaz
I have used a single product:
http://www.amazon.co.uk/Vanish-Oxi-Action-Power-Foam-600ml/dp/B003VALYPG
I have applied this product alone, no other product mixed with it.
Before testing the product on the whole case, I have tried putting a small drop on some hidden part. Two hours after, the circle under the drop was clear beige!
Then, I have taken appart the HP85, and have covered the upper side with a thick layer of Vanish-Oxi-Action foam. Couple hours later it was clear beige. Not exactly the tone at the bottom side but almost there. It was a little darker. Probably the process could be repeated to clear up the tone even further but it has done a wonderful job! Probably it would work as well in less than 2 hours.
