HP-97 suddenly not working Message #1 Posted by Brad Barton on 15 Feb 2013, 5:03 p.m.
I recently acquired a very nice HP-97. The card reader needed the sticky wheel repair, but the seller kindly included a baggie full of the proper sized o-rings with the purchase. Also the printer didn't feed paper too well, but that seemed like an easy fix as well.
Before I got to fixing those two problems, I used the 97 as a desktop calculator for a couple of weeks, enjoying just having it for a while before I attempted repairs. It came with a good battery pack and a 2 prong charger. I would unplug it at night, and leave it plugged in during the day while I was at my desk. I wanted to use if for a while before I took it apart, just in case I ruined it somehow.
A few days ago, disaster struck. I turned the 97 on for the day, and all I got was a string of 0's with a negative sign at the extreme left. A little research tells me that the ACT chip is probably burned out.
I went ahead and disassembled it, noting the location of the ACT, and did the aforementioned repairs. Quite easily accomplished with the resources here on MoHPC, so thank all of you who have posted about those particular repairs. Of course I was hoping that by disassembling/reassembling the unit it would be revived by some miracle, but it was not to be. Still all 0's when I turn it on.
So this leads to my questions. Is there a way to test the ACT chip ? I saw a post by Ignazio where he cannibalized a 97 to use a a test bed, but since he's in Italy, and I'm in the US, I doubt that he can help. Are there other ways to test it? I have an oscilloscope, but am a mechanical type, with electrical dyslexia.
I thought about cannibalizing my HP-25, but I'd rather not. I'm in the process of getting it working, and would rather have both working reliably. Of course if the 25 fails to come through, that ACT would be available.
Also, could it be something else? Maybe there are other chip failures that produce a similar result.
Finally, could the way I charged the unit every day have lead to the demise of the ACT? It was never plugged in without the battery pack, even though the manual says that wouldn't damage the unit, but might lead to improper results.
