HP Forum Archive 21
HP41 Blank formulars for program documentation?
Message #1 Posted by Wolfgang on 13 Feb 2013, 10:28 p.m.
Does any body has blank form sheets for program documentation which he can scan and distribute? I have a bunch of these for user programs and like to get my own program documentation in line with this format.
From what I see the documentation was as follows:
1. Program Description I 2. Program Description II 3. User Instructions 4. Program Listing 5. Register,Status,Flags,Assignments 6. Keyboard Labeling
following where additional program descriptions and at last bar code sheets.
I hope that not only for me it would be very welcome if someone has blank form sheets and could make scanned copies available.
I found in the MoHPC forum a link to a file called "Programming Pad.pdf" But that looks more like the TI "Program Record" sheets for the SR56 and TI59.
Edited: 13 Feb 2013, 10:29 p.m.
Re: HP41 Blank formulars for program documentation?
Message #2 Posted by Sylvain Cote on 14 Feb 2013, 1:46 a.m.,
in response to message #1 by Wolfgang
You can find the form you are searching at TOS.
Message #3 Posted by Massimo Gnerucci (Italy) on 14 Feb 2013, 4:05 p.m.,
in response to message #2 by Sylvain Cote
That's right!
[TOS]/LibView.cfm?Command=View&ItemID=489
Massimo
Message #4 Posted by Wolfgang on 15 Feb 2013, 11:08 p.m.,
Thanks for your help. I got now excellent word documents and also scans of the originals.
