More or less dead HP-67 Message #1 Posted by Bernd Ulmann (Germany) on 8 Feb 2013, 4:37 p.m.
Hi -
I recently acquired a HP-67 in non-working condition and was hoping to restore it, but I have to admit that I have run out of ideas by now.
The symptoms are as follows:
- Display shows 00000.0 at power up.
- No numbers can be entered, pressing most keys just causes the display to go blank for a blink and then 00000.0 is displayed again.
- Switching the RUN/PGM-switch to PGM causes the display to flicker rhythmically as if the machine were executing some program.
- The top-row keys cause the display to go blank and stay blank, pressing the division key results in the display of Error (maybe it tries to divide by zero which is in the display).
I checked this:
- +6.2 and -12V are there and there is no noticeable ripple on either voltage.
- PHI1/2 are there, swinging from +6.2 to -12V.
- The keyboard lines KCx are all high as long as no key is pressed.
What puzzles me is that I can see a nearly saw-tooth signal on the DATA pin (11 on the ACT) with a 5 us period. All other lines like SYNC and ISA have signal patterns that look reasonable after what I read on Jacques Laporte's pages describing the HP-35.
Does anybody have any ideas what I could/should check next? I can take pictures from my oscilloscope and post them to clarify things if necessary.
All the best - sincerely, Bernd. :-)
