HP Forum Archive 21
OT: 3D Calculator Remakes
Message #1 Posted by hugh steers on 28 Jan 2013, 8:54 a.m.
Hello everyone,
Because mobile devices are insanely powerful, i've been developing calculators in 3D. The idea is to remake the exact likeness. Here are links to my products:
iOS, App Store
Android, Google play
It's been quite a big effort, so the apps are not free. However, I can provide an Android demo version and some iOS promo codes if anyone is interested to try it out (email me).
My main question here though, is that I'm thinking of making a 3D RPN HP next. I've been contemplating doing one from the spice series because i think the red LED would look great - of course a classic is possible as well.
I should say that i've already ruled out doing the 41 because, as you know, there are many excellent emulators that do a fantastic job. My remakes are not emulators and in cases like the 41, people would expect original 41 programs to work 100%. In particular, for the product listed above, the results of calculation are better than the original. There's no point in me reproducing old numerical limitations when running on modern hardware (for those interested, no i don't just use built-in floats, it's all proper decimal arithmetic).
Comments & Suggestions welcome.
-- hugh.
Re: OT: 3D Calculator Remakes
Message #2 Posted by Walter B on 28 Jan 2013, 9:35 a.m.,
in response to message #1 by hugh steers
Good grieve, not sure I got you right: Are you going to make real calculators of real plastic material? Or is it just going to be a 3D simulation?
Message #3 Posted by hugh steers on 28 Jan 2013, 11:08 a.m.,
in response to message #2 by Walter B
Hello Walter,
No, there's no plan to make physical calculators! These are simulations for iPad or Android phones and pad.
The difference here is that the simulation is a live 3D object that you can manipulate so that the buttons and switches actually move in 3D.
Message #4 Posted by Alexander Oestert on 28 Jan 2013, 11:11 a.m.,
Hugh,
your demo video looks amazing! I very much hope you will realize your plan to make an LED HP model. I will be seriously tempted to buy one for my Android tablet.
Message #5 Posted by hugh steers on 28 Jan 2013, 1:01 p.m.,
in response to message #4 by Alexander Oestert
Thanks!
I plan to start modelling the next model soon(ish). The measurements are taken very accurately with callipers from real machines. The bevelled buttons of HP models should work very well in 3D. I've noticed that most implementations use a picture which is fine for face-on buttons, but you cannot read the legends on the slanted parts too well. But in 3D, this should be rectified.
I spent some time getting the VFD segments and glow looking right in the current model. It's not just a picture! The glow is calculated and, if you look close, you can see that the illumination of the surrounding is dependent on proximity to a lit segment - as it should be. I'd like to spend the same effort to make a red LED look just right and glow properly too.
That's another good reason to make one of the older models.
Edited: 28 Jan 2013, 1:01 p.m.
Message #6 Posted by Geoff Quickfall on 28 Jan 2013, 12:23 p.m.,
The battery hatch will not open. How does one change the batteries? Has anyone else got a jammed battery hatch.
Now to find the simulated 3d box so I can send it back.
Major flaw!
Message #7 Posted by hugh steers on 28 Jan 2013, 12:53 p.m.,
in response to message #6 by Geoff Quickfall
Yes, Everybody has been asking for the battery compartment to open!
i'm seriously thinking about implementing it for the next release. Of course, will they then expect to remove the batteries and put in new ones? You can see where this is leading :-)
Message #8 Posted by Tim Wessman on 28 Jan 2013, 12:58 p.m.,
in response to message #7 by hugh steers
You will probably need to make a desk drawer that it can be removed from to use... and a driving simulator to go to the store and buy new batteries..
This could get interesting quick! ;-)
TW
Message #9 Posted by hugh steers on 28 Jan 2013, 1:05 p.m.,
in response to message #8 by Tim Wessman
yes exactly!
I think you should point out here, that the logical conclusion for people who want it completely true to life, is to buy the real calculator!
Message #10 Posted by Geoff Quickfall on 28 Jan 2013, 1:06 p.m.,
A simulated FedEx return facility and ...
Bu t really folks, WONDERFUL APP! I am amazed.
Now, stick the credits under the sliding battery door panel with a link to your handycalc and starflight.
cheers
Message #11 Posted by Geoff quickfall on 28 Jan 2013, 1:07 p.m.,
in response to message #10 by Geoff Quickfall
Or a snide comment, like " you were expecting batteries?"
Message #12 Posted by hugh steers on 28 Jan 2013, 1:13 p.m.,
in response to message #11 by Geoff quickfall
it's worse than that.
What make of batteries specifically? you can see that i've thoughts of this! because then i'm in trouble with trademarks and all sorts of stuff. I guess i could have some no-name made up batteries. but then it wouldn't look right!
Message #13 Posted by Harald on 28 Jan 2013, 2:54 p.m.,
in response to message #12 by hugh steers
Also you could have rechargeable batteries. And of course a charger. That would enable you to sell extra sets of batteries one doesn't have to wait for the batteries to recharge before continuing to work ;)
I really like this, the only problem is, I don't have a smart phone ;)
Message #14 Posted by hugh steers on 28 Jan 2013, 1:23 p.m.,
FYI,
The iPad mini runs at 27 FPS. It's doing 4xMSAA to look smoother and running two dynamic lights with phong shaded specular reflection (one on each side). You can change the light intensity and, if you tilt the unit, you can slightly move the lights to affect the reflection shine (although the iPad has a habit of rotating the view if you go too far).
I whip the GPU :-)
Message #15 Posted by hpnut on 29 Jan 2013, 1:09 p.m.,
TW
and your car gets hijacked a la Grand Auto Theft...the fun possibilities are endless
Message #16 Posted by Egan Ford on 28 Jan 2013, 1:31 p.m.,
You could drop the price to $0 and make batteries an in-app purchase good for x hours of use.
Message #17 Posted by hugh steers on 28 Jan 2013, 1:45 p.m.,
in response to message #16 by Egan Ford
Hi Egan,
Yes, i seriously considered that. Except that it would be *really* annoying if you were out and wanted to use it or show it, then the battery dies!
What i might do, is release a free version as a demo where the batteries run down and the screen gets dimmer. You'd still be able to play with the 3D model, but it wouldn't calculate. Then if you upgraded to the real version, it would just work normally.
Message #18 Posted by Egan Ford on 28 Jan 2013, 4:16 p.m.,
in response to message #17 by hugh steers
Or just return the wrong answer. Or return "42" for every answer.
Message #19 Posted by Ren on 1 Feb 2013, 3:42 p.m.,
The battery door NEEDS to open! The users may have to short out the battery clips with a virtual paper clip from time to time.
Message #20 Posted by Dave Shaffer (Arizona) on 1 Feb 2013, 3:59 p.m.,
in response to message #19 by Ren
And then it can fall off, a la the 28S!
Message #21 Posted by Egan Ford on 28 Jan 2013, 1:33 p.m.,
Comment.
Store a history of buttons used and then reflect that as grime on the keyboard and then sell alcohol wipes as in-app purchase.
Message #22 Posted by Geoff Quickfall on 28 Jan 2013, 1:35 p.m.,
in response to message #21 by Egan Ford
Ha!
Message #23 Posted by hpnut on 29 Jan 2013, 1:05 p.m.,
nice job, Hugh. I would buy your HP, please make it an HP67 or HP25C or any red LED HP.
cheers,
hpnut in Malaysia
Message #24 Posted by Geoff Quickfall on 29 Jan 2013, 2:37 p.m.,
in response to message #23 by hpnut
Got to agree with HPnut, a 67, yep!
Message #25 Posted by Maximilian Hohmann on 29 Jan 2013, 4:24 p.m.,
in response to message #24 by Geoff Quickfall
With magnetic cards! And probably the most Inexpensive hp 67 wie are ever going to buy.
Message #26 Posted by hugh steers on 29 Jan 2013, 4:49 p.m.,
in response to message #25 by Maximilian Hohmann
the 67 will have to be later!
I've started measuring the cases of the spice models. I'm assuming they all have the same basic case shape. This could be very good because, i could make make *all* of the series in one app.
Message #27 Posted by Eddie W. Shore on 31 Jan 2013, 9:12 a.m.,
Hugh,
You have me curious - I just bought the app.
I like the novelty moving the calcualtor around as if I was working with a tangible calculator. Good job!
Edited: 31 Jan 2013, 9:20 a.m.
