Re: Snake for HP39GII Message #5 Posted by Gilles Carpentier on 25 Jan 2013, 12:57 p.m., in response to message #4 by Mic
It works ... I'd send to you the file v1.1
In fact I had no understood that I need the emulator 'on' to transfer a file from the real calc to the PC. It seems you can't do this with the connectivity kit which works directly in the calculator memory and copy nothing on the PC (at least it seems work like this)
With XP, the binaries files are in
C:\Documents and Settings\_user_name_\Application Data\HP39gII
Edited: 25 Jan 2013, 12:58 p.m.
