HP 12 C simple interest calcuation Message #1 Posted by sam on 15 Jan 2013, 12:32 p.m.
Hi all,
I am new to this forum. Recently, I am excited by the HP 15C limited edition and trying to recall the memory of using my Singapore version of HP 12C as well.
Back to the subject, I want to calculate the principal which will accumulate to $10,000 at simple rate 7% p.a. over two years.
FV = 10,000
i = 7
n =2
The PV is calculated as -8,734.39.
As you may know, this is not correct given the formula PV*(1+2*0.07)=10,000. The correct PV should be 8,771.93
I figure out that it is the default compound interest calculation in HP 12C.
My question is that is there a way to make HP 12C use simple interest method to work out the PV? I understand there is a key STO EEX for old period calculation but it seems that is not useful here.
I would appreciate your assistance. Many thanks.
Sam
