Re: [WP 34s] Polar & Rectangular Number Display Message #8 Posted by Jeff O. on 15 Jan 2013, 9:09 a.m., in response to message #7 by Walter B
Walter,
I do not wish to beat a dead horse* here, I accept that you and Pauli see no great value in my proposed polar and rectangular display modes, so am not asking for further consideration. But I do want make another point or two. Regarding providing the two-line display for Complex, Polar to Rectangular and Rectangular to Polar results but not all of the other instances you listed where both x and y are modified by a function: I feel that those three instances rise above the others because the two components taken together form one mathematical entity. So it is appropriate to show both components upon execution. (I did not review all other cases which return results to the x and y stack levels, so perhaps this line of reasoning applies to other cases as well.)
As I wrote more than once from the very beginning of this project: this breathtaking display is the limiting factor.
Agreed, the display is very limiting, and you and Pauli and Marcus have probably squeezed as much out of it as is possible. But I will defend the display a little. Given the 400 element limit imposed by the hardware (as I understand things), it is about as good as could be done. Look at all the WP34s team has accomplished with it, after all.
How about "confirmation and preview of results" in an HP-41CX or an HP-15C? You can trust your WP 34S
I hope there is not a misunderstanding with my use of the word “confirmation”, but just in case, I will clarify. I meant that it would provide confirmation of what you just did, i.e., that you just performed a >POL or >REC and now have such a result in stack x and y. I did not mean to imply that I needed confirmation that my WP34s had acted correctly. I trust my WP34s.
Thanks for listening.
Jeff
* - I in no way advocate the beating of any animal, live or dead. I believe that this English language idiom has been discussed previously in this Forum. It is just a short way of saying “here comes more discussion on something that has already been discussed a lot and everyone is probably tired of hearing about.”
