GROBs with hidden data in them... Message #1 Posted by Chris Dreher on 13 Dec 2012, 5:58 a.m.
I've read proposals over the years that data can be hidden inside GROBs by taking advantage of the unused bit fields.
Has anyone ever heard of someone actually doing that? Even better would be if someone could point me towards an HP48 program or an example GROB with such hidden data.
I've already done the obvious searches of hpmuseum, comp.sys.hp48, and hpcalc.org and only found a few people saying it can be done.
Background: GROBs store each row of pixels as consecutive bits. To make memory management easier, the number of bits is rounds up to the nearest multiple of 8 bits. Thus, a GROB that is 9x6 or 10x6 or 11x6 will all store their pixels as 16x6 bits. This round up adds extra bits to the end of each row that the calculator doesn't use so theoretically you can put your own data into there.
