Re: Question about X modules for HP41x Message #3 Posted by Dan Grelinger on 11 Dec 2012, 12:16 p.m., in response to message #1 by Ignacio Sánchez Reig
To add some detail to Angel's response...
The "Aviation" and "Aviation X" modules are identical, except for their labelling. Due to the limited number of XROM numbers (max of 31), HP determined that some modules would have to use identical XROM numbers. Since modules with identical XROM numbers will interfere with each other if they are installed in an HP-41C at the same time, HP selected a group of modules from differing disciplines for which users interests would not overlap. These modules were all assigned XROM 19. At one point, HP thought that it was necessary to clue the user into the fact that these modules were incompatible with each other by adding an "X" designation to the module name.
These are the HP 'X' modules that will conflict with each other if installed in the HP-41C at the same time.
- Aviation (with or without the 'X')
- Clinical Lab X
- HP-IL Diagnostic
- Securities X
- Strc Anal (with or without the 'X')
So, if you were a nuclear pharmacist, designing your own home, managing your own investments, flying your own airplane, and with an interest in designing HP-IL equipment, you could not have more than one of these modules plugged into your HP-41C at any one time for fear that the program in one module would inadvertently call a program in another module as a subroutine. Disaster would ensue, your patients would die, you'd lose your retirement investments, your house would fall down from poor design, you'd crash your airplane, and after all that, your HP-IL analysis would not work. Bummer.
