Re: Error Message/Procedure HP-48SX with TDS Survey SX card Message #5 Posted by bporter101 on 8 Dec 2012, 12:23 p.m., in response to message #4 by Han
Thank you for responding, Sorry I tend to overthink my answers anb will clearify.
I would try putting the ROM card into slot 2, and the RAM card into slot 1 and MERGE'ing card slot 1 with main memory. Then run
TDS48.
Response
I have tried this,
When I Merge memery to port 2 and run TDS48 the program installs then askes to "turn off and insert memory card into port 2" I turn the hp-48 off and then back on again type (Alpha) (Alpha) tds48 and the program begins to load (I see the copyright) up but then errors out with the message "Port 2 unconfigured"
What do you mean by "Memory card" -- both ROM and RAM cards are memory cards. Do you mean the software (ROM) card? or the RAM card?
Response
Sorry about that, I was thinking a Program card and Memory card. but in this case I was talking about RAM Card.
My understanding is that the HP48GX software works differently in that you do you have initially use card slot 2 for the ROM card and then do a swap to card slot 1.
Response
Yes that is correct. I assumed that all of the TDS software did this.
I got confused reading this: you say "got it working" and then immediately describe how it is not working... ?
Response
Sorry, What I ment was I got the software to initalize and start up to the main menu howeve when I try to create a job I have the issue stated and counld not test any further. The use of the HP-48GX was used to verify that the Program Card (ROM) Card was working correctly.
Are you getting a "Try to Recover Memory" prompt? Is that what you mean by clearing all memory? Or is it asking to initialize the RAM card?
Response
No, when I attempt to Create a Job it gives me the normal job setup screen, I then give it a name and select "Create" it immediately goes to "Delete all data in port 2? (Y/N)"
If I say yes, it dropes me out of the program and does not create the new job. I then go back into the software TDS48 and try it again however it does the same thing.
When I say No, it dropes me out of the program TDS48 and states data not saved. I then go back into the software TDS48 and try it again however it does the same thing.
Thank you, I hope this helps clearify.
