Riemann's Zeta Function (HP 50g) Message #1 Posted by Gerson W. Barbosa on 4 Dec 2012, 3:59 p.m.
This is a follow-up of a recent thread on the Zeta function . On the occasion Thomas Ritschel wrote an RPL program based on Euler-MacLaurin summation, which was much faster and efficient than my previous attempts. The following is based on the same method, as described in the book Riemann's Zeta Function, by H. M. Edwards (pages 114 through 118).
Zeta:
%%HP: T(3)A(D)F(.);
\<< RCLF SWAP -22. SF RAD 1. CF DUP RE 0. <
IF
THEN 1. SF NEG 1. +
END 10. 8. 0. \-> s n m b
\<< '\GS(k=1.,n-1.,k^-s)' EVAL n 1. s - ^ s 1. - / + n s NEG ^ 2. / + BNL 1. 2. m
FOR i GETI s i + 1. - GAMMA * n 1. i - s - ^ * s GAMMA / i ! / 'b' STO+ 2.
STEP b NIP NIP + 1. FS?
IF
THEN 1. s - DUP 2. / \pi * SIN 2. ROT ^ * * s DUP GAMMA \pi ROT NEG ^ * *
END
\>> SWAP STOF
BNL:
%%HP: T(3)A(D)F(.);
{ .166666666667 -3.33333333333E-2 2.38095238095E-2 -3.33333333333E-2 7.57575757576E-2
-.253113553114 1.16666666667 -7.09215686275 54.9711779449 -529.124242424
6192.12318841 -86580.2531136 1425517.16667 -27298231.0678 601580873.901
-15116315767.1 429614643062. -1.37116552051E13 4.88332318973E14 -1.92965793419E16
8.41693047575E17 -4.03380718541E19 2.11507486381E21 -1.20866265223E23 7.50086674608E24 }
%%HP: T(3)A(D)F(.);
\<< { } 2. 50.
FOR n n IBERNOULLI \->NUM + 2.
STEP 'BNL' STO
This produces the list with the first twenty-five even-order Bernoulli numbers above. The Zeta program above uses only the first four (n=8), which is suffices for the examples below. However complex arguments will require more terms as their modules grow larger, as we'll see in other examples.
Values of Zeta(s) for some real and complex arguments:
s | Zeta(s) | time(s) | exact value
8. | 1.00407735620 | 0.487 | pi^8/9450
7. | 1.00834927741 | 0.489 |
6. | 1.01734306199 | 0.493 | pi^6/945
5. | 1.03692775515 | 0.484 |
4. | 1.08232323370 | 0.488 | pi^4/90
3. | 1.20205690316 | 0.481 |
2. | 1.64493406685 | 0.479 | pi^2/6
1. | 9.99999999999E499 | 0.476 | infinite
0.5 | -1.46035450882 | 0.701 |
0 | -0.500000000000 | 0.388 | -1/2
-0.5 | -0.207886224977 | 0.785 |
-1. | -8.33333333331 | 0.521 | -1/12
-2 | 4.00788420761E-15 | 0.523 | 0
-3 | 8.33333333323 | 0.535 | 1/120
-4 | -2.10179397707E-15 | 0.537 | 0
-5 | -3.96825396829E-3 | 0.543 | -1/252
-6 | -2.3297903572E-15 | 0.537 | 0
-7 | 4.16666666665E-3 | 0.540 | 1/240
(1.,2.) | (0.598165569758, | 3.512 |
| -0.351854745216) | |
(3.,4.) | (0.890554906967, | 3.375 |
| -8.07594542632E-3) | |
(-5.,6.) | (1.42843389347, | 3.504 |
| 0.184238641590) | |
Let us experiment with different numbers of zeta terms (n) and Bn terms (m/2) of the Euler-MacLaurin summation for a few arguments in the positive complex half-plane and observe their influence on the overall accuracy using the program below.
%%HP: T(3)A(D)F(.);
\<< 0. \-> s n m b
STEP b NIP NIP +
s | n | m | Zeta(s) | time(s)
2 | 5 | 4 | 1.64493377778 | 0.330
2 | 5 | 8 | 1.64493406547 | 0.438
2 | 7 | 4 | 1.64493403873 | 0.371
2 | 7 | 8 | 1.64493406681 | 0.483
2 | 8 | 10 | 1.64493406685 | 0.521
2 | 10 | 8 | 1.64493406685 | 0.464
0.5 | 4 | 4 | -1.46035496134 | 0.394
0.5 | 4 | 6 | -1.46035444845 | 0.491
0.5 | 4 | 8 | -1.46035451114 | 0.586
0.5 | 8 | 10 | -1.46035450881 | 0.743
0.5 | 10 | 8 | -1.46035450881 | 0.684
(0.5,18) | 6 | 8 | (2.32919185455,-0.188602491388) | 3.545
(0.5,18) | 12 | 16 | (2.32915487303,-0.188866005798) | 7.075
(0.5,18) | 20 | 20 | (2.32915487307,-0.188866005802) | 9.247
(2.5,-100) | 12 | 16 | (1.02952895989,5.76320966153E-2) | 6.753
(2.5,-100) | 25 | 22 | (1.13221432860,3.98766176236E-2) | 9.704
(2.5,-100) | 36 | 28 | (1.13221432259,3.98766168104E-2) | 12.049
(0.5,14.13472514) | 20 | 16 | (2.185000000E-10,-1.35802000E-9) | 12.049
Here is the equivalent HP-71B BASIC program. Because GAMMA() on the HP-71B doesn't handle complex arguments, it will work only on the real domain.
10 DESTROY ALL @ OPTION BASE 1
12 REAL S,Z,B(15)
14 INTEGER I,N,M
16 INPUT S,N,M
18 FOR I=1 TO 15
20 READ B(I)
22 NEXT I
24 Z=0
26 FOR I=1 TO N-1
28 Z=Z+I^(-S)
30 NEXT I
32 Z=Z+N^(1-S)/(S-1)+N^(-S)/2
34 FOR I=2 TO M STEP 2
36 Z=Z+B(I DIV 2)*GAMMA(S+I-1)*N^(-S-I+1)/(GAMMA(S)*FACT(I))
38 NEXT I
40 PRINT Z
42 END
44 DATA 1/6,-1/30,1/42,-1/30,5/66,-691/2730,7/6,-3617/510,43867/798,-174611/33
46 DATA 854513/138,-236364091/2730,855303/6,-23749461029/870,601580873.901
>run
? 2,5,4
1.64493377777
>run
? 0.5,4,4
-1.46035496134
>run
? 2,5,8
1.64493406546
>run
? 0.5,4,8
-1.46035451114
The following program HP-71B program will accept both real and complex arguments:
12 COMPLEX P,S,Z
14 REAL B(15)
16 INTEGER I,N,M
18 INPUT S,N,M
20 FOR I=1 TO 15
22 READ B(I)
24 NEXT I
26 Z=0
28 FOR I=1 TO N-1 @ Z=Z+I^(-S) @ NEXT I
30 Z=Z+N^(1-S)/(S-1)+N^(-S)/2
32 P=1/(S-1)
36 P=P*(S+I-3)*(S+I-2)
38 Z=Z+B(I DIV 2)*P*N^(-S-I+1)/FACT(I)
40 NEXT I
42 IF IMPT(S)=0 THEN PRINT REPT(Z) ELSE PRINT Z
46 END
48 DATA 1/6,-1/30,1/42,-1/30,5/66,-691/2730,7/6,-3617/510,43867/798,-174611/33
50 DATA 854513/138,-236364091/2730,855303/6,-23749461029/870,601580873.901
>run
? 2,5,4
1.64493377777
>run
? 0.5,4,4
-1.46035496134
>run
? (0.5,18),6,8
(2.32919185455,-.188602491387)
Both programs require the Math Module. I haven't tested them on the real hardware, but the running time should be fast enough.
Edited: 4 Dec 2012, 4:14 p.m.
