HP 65 card reader problem Message #1 Posted by H Fischer on 22 Nov 2012, 6:58 a.m.
this is my first posting here, but I know HP calculators since 1973 and use them since 1975.
Recently I came across a HP 65 in unknown condition. According to the vendor, it had been used for surveying in the middle east, and yes, it was full of dust and dirt, and everything is quite worn out. The number keys don't click any more, as the springs have become soft.
But, after a lot of cleaning and replacement of the keyboard plastic foil, the card reader rubber wheel and the battery cells, it works nicely again. Since a long time, I wanted to see this LED display!
However, I can't get the card reader to work. All parts are clean and in the places where they should be, the motor and the wheel work when I apply external voltage, the switches operated by the nylon balls look o.k. and the contacts are clean. When I insert a card, I can hear the "click" of the switches, but the motor just doesn't start.
Any idea what I could try next?
Thanks, Helmut
