Re: Bllinky's internals Message #2 Posted by Luiz C. Vieira (Brazil) on 20 Nov 2012, 11:26 a.m., in response to message #1 by Mike (Stgt)
HI.
I always suspected the IR module HW has some relation to the HPIL, mostly because of the HPIL printer functions subset. What always called my attention is the fact that once the IR module is plugged in, the HP41 needs a brief moment - less than a second - to wake up after [ON] key is pressed. And this happens all the time, as if an HPIL is plugged in and the loop is opened.
Have you compared the MCode of the IR functions with the equivalent HPIL printer functions, at least some of them? Chances are they share some structure.
Not an answer to what you asked, I know, but chances are it may lead to some find-outs.
Success!
Luiz (Brazil)
Edited: 20 Nov 2012, 11:26 a.m.
