Re: HP200LX Connectivity SW Message #4 Posted by Mike (Stgt) on 6 Nov 2012, 5:50 a.m., in response to message #3 by Bart (UK)
If its just for the connection you may use Kermit (if you have that serial cable). If it is for the software or the installation disks - then the a. m. linkt to Franz may help.
BTW, the software of the communication kit is compiled from the same source as the software on the HP200LX itself (codenamed Felix). There is a 80MB bundle of the sources somewhere, alas not the latest HP200LX version.
What I badly miss in the Communication Pack is the edit/copy - edit/paste from one application to an other. And the Lotus-123 in conjunction with the graphing Calc. :(
The HP200LX was not only a nice PIM at it's time, it is an 'All-You-Need-In-DOS' machine on your palm with a useful keyboard - with a separate number block. IMHO still today 2nd to none.
Ciao.....Mike
