Re: Samson Cables has a few HP 15C Limited Edition Message #7 Posted by BobVA on 22 Oct 2012, 6:23 p.m., in response to message #6 by Bill Duncan
The reissue had some problems with the keyboard, which I believe were sorted out in later production (typically keys registering two entries for one press). I had one replaced (quite promptly) under warranty for that problem.
Katie collected and posted this bug list a while back that you should look over to see if there are any deal breakers for you.
That said, I use mine all the time and find it to be a good replacement for the older version, warts and all. It is *extremely* fast compared to the original, which has a quality all of its own :-)
Bob
Edited: 22 Oct 2012, 6:26 p.m.
