HP Forum Archive 21
Can the display for a HP32Sii be replaced with the display from another model?
Message #1 Posted by Bruce Larrabee on 9 Oct 2012, 9:45 p.m.
Does anyone know if the display for a HP32Sii be replaced with the display from another model?
Re: Can the display for a HP32Sii be replaced with the display from another model?
Message #2 Posted by Luiz C. Vieira (Brazil) on 9 Oct 2012, 10:05 p.m.,
in response to message #1 by Bruce Larrabee
Hi.
IIRC, some Pioneers share the same display. The HP14B seems to be a suitable replacement, although I have two of them that are almost totally dark. I guess the polarizer is the guilty one in this case.
I'd give a try to the HP22S, not sure about the HP21S
Success!
Luiz (Brazil)
Message #3 Posted by Marcus von Cube, Germany on 10 Oct 2012, 4:03 p.m.,
in response to message #2 by Luiz C. Vieira (Brazil)
The 21S does not have a matrix display, only a seven segment display.
Message #4 Posted by BruceH on 10 Oct 2012, 4:59 p.m.,
in response to message #3 by Marcus von Cube, Germany
More importantly, the 21S is an unsung classic. Dismantling one to fix a 'lowly' 32Sii would be terrible.
Message #5 Posted by Christoph Giesselink on 10 Oct 2012, 6:21 p.m.,
in response to message #4 by BruceH
Agree, it was quite hard for me to get a 21S in the last years. But I don't know which was more difficult, to get the 21S or the 22S?
Message #6 Posted by Luiz C. Vieira (Brazil) on 10 Oct 2012, 10:06 p.m.,
Ditto.
Message #7 Posted by Christoph Giesselink on 10 Oct 2012, 2:02 p.m.,
No it can't for sure from the visual aspect. The 14B, 22S and 32S use the same display. The 32SII display has differen't annunciator segments.
From electrical and mechanical aspects this may work because all Mid range pioneers use the 1LR3 Sacajawea chip.
This address http://hp.giesselink.com/Pict/SacaLCD/Design.htm is a reference to my Mid Range Pioneer LCD designs for Emu42. You may have a look inside the KMI files how the annunciators are connected.
Christoph
Edited: 10 Oct 2012, 4:13 p.m.
Message #8 Posted by Raymond Del Tondo on 10 Oct 2012, 4:30 p.m.,
in response to message #7 by Christoph Giesselink
I want to add that older 32S units with the protective glass covering the LCD area have the same LCD as the 14B and 22S, but newer 32S units with recessed LCD have a slightly different LCD with larger pixels, much like in the 32SII ;-)
Raymond
Message #9 Posted by Luiz C. Vieira (Brazil) on 10 Oct 2012, 10:05 p.m.,
Hi.
I for one would like to thank for the clarifications. I was not aware about these differences (never had an HP22S nor an HP32S/SII), all I knew was that they had display similarities. Not an excuse, I know...
Cheers.
Luiz (Brazil)
