Re: Help with creating residual plot Message #2 Posted by Andrew Feist on 10 Oct 2012, 12:49 p.m., in response to message #1 by Phillip B.
I've got a 48gII, not a 50, but my understanding is that it's similar enough to be getting on with. The question then becomes: how are you creating your L1, your L2, and your Y1?
A bit of playing around shows that if I have something like '.505+1.475*X' stored into Y1, if I then execute Y1 on a list L1 (in either RPN or alg mode) I get a result list whose first element is .505 and the other elements are 1.475 times the elements of L1.
If I write Y1 instead using "ADD" instead of + (in RPN, << 1.475 * .505 ADD>>; probably something similar in alg) then it works as expected. Also, if I rewrite the equation to '1.475*X-(-.505)' it works as expected.
It looks like + is the only operator that doesn't act on each member of a list, which seems a little annoying.
