Re: 9114 drive "rod knock"? Message #2 Posted by Luiz C. Vieira (Brazil) on 5 Oct 2012, 12:32 a.m., in response to message #1 by BobVA
Hi.
Any chance to check for a loose, small bolt/nut/spring or anything else at the driver mechanics? Or any misplaced existing part under the driver mechanics?
I have one 9114A and one 9114B, both working fine (hard to find good 720K disks, though...), and both have two different disk drive units. Based on what you mentioned, considering that units are compatible, you may also 'transplant' one of the driver mechanics from one of the two broken units, right?
Please, let us know how it goes.
Success!
Luiz (Brazil)
