Re: HP 75 Assembly Language Message #4 Posted by Michael Fehlhammer on 30 Sept 2012, 4:02 p.m., in response to message #3 by Sylvain Cote
Thank you for your hints, Sylvain.
I found the forth.org page and the forth assembler/disassembler for the HP 75c, but I am not sure whether that package contains the mentioned machine code assembler / disassembler extensions (like the forth/assembler module for the HP 71 does); probably it doesn't. Any idea where I could find such extensions, preferably documented?
Theoretically, in order to create HP-75 mcode routines, it's possible to study the NOMAS listings, use a 80 series development platform and adjust the output files, but that certainly is the very hard way. That's why I am still looking for a more convenient solution, like the mentioned German book which seems to be kind of tutorial for HP-75 mcode programming - including a disc providing mcode assembler and disassembler.
