HP 49G print format - Solved Message #1 Posted by Olivier De Smet on 8 Sept 2012, 11:03 a.m.
While finishing an hp 49 g emulator for android, I stumbled on a strange behavior.
When printing in serial mode, PRLCD command send data compatable with the old HP82240 (visine) printer for graphic (ESC codes and so on).
But when using ON&UP shortcut, another format is used for graphic printing.
Did someone knows the differences about that ?
(a quick search on the HP49G(+) AUR did not give a result)
(BTW it's with a 1.19-6 rom)
Ok, got it (in looking in an old conn4x source code in delphi), it seems that ON&UP just dump horizontally a bitmap of the screen with a 128,87 2 bytes prefix.
Edited: 8 Sept 2012, 12:23 p.m.
