Re: Complex number calculation on wp34s Message #9 Posted by Ángel Martin on 30 Aug 2012, 5:09 a.m., in response to message #7 by Walter B
This is a typical example. Either Real^Imaginary or Imaginary^Real is the most basic notion needed to use a complex-capable calculator. One can't assume all models do it the same way, so a quick check (either reading the manual or doing a simple operation to confirm) is in order.
For instance, the 41Z does it either way, depending on the preferred method:
- Im^Re if using the complex stack
- Re^Im if via the "^IM/AG" function.
Cheers,
ÁM.
Edited: 30 Aug 2012, 5:12 a.m.
