Re: Problems concerning HP 82104 card reader Message #2 Posted by Luiz C. Vieira (Brazil) on 21 Aug 2012, 9:25 a.m., in response to message #1 by Edward Cheng
Hi.
I assume you have already red this thread as well, so the correct external diameter pointed out by Randy (last follow-up) should be 6.35mm.
Also, there is the pulling gear issue. It's been discussed some points about how should the pulling gear be connected to the motor shaft, and the use of flexible, silicon-based glue or rigid glue has been considered. In any case, chances are that the gear is not firmly connected to the motor shaft if it is spinning freely. I could not locate the other threads about this subject.
Not so much of a help, sorry!
Luiz (Brazil)
