Re: Estimating Accumulated Rounding Errors Message #5 Posted by hugh steers on 15 Aug 2012, 8:24 p.m., in response to message #1 by Egan Ford
don't estimate the errors - know them! or rather their upper bounds.
i suggest the field of validated computing, which i have been looking at for
some time. This is the use of interval arithmetic to bound your computations.
http://en.wikipedia.org/wiki/Interval_arithmetic
you have to define a new number class with the usual operators, which holds an
interval [Inf, Sup]. Where your true real value is somewhere Inf <= x <=
Sup. The operators maintain the error window whenever you perform
arithmetic. If you have, say a Taylor series of arctan, you have to also
expand the window by the max error of your truncation and so on.
some years ago i successfully built a calculator around this idea.
(windows exe) www.voidware.com/exact/exact.exe
eg
exact -acc 2000
pi()
increasing precision to 2012 =
3.14159265358979323846264338327950288419716939937510582097494459230781640628620899862803482534211706798214808651328230664709384460955058223172535940812848111745028410270193852110555964462294895493038196442881097566593344612847564823378678316527120190914564856692346034861045432664821339360726024914127372458700660631558817488152092096282925409171536436789259036001133053054882046652138414695194151160943305727036575959195309218611738193261179310511854807446237996274956735188575272489122793818301194912983367336244065664308602139494639522473719070217986094370277053921717629317675238467481846766940513200056812714526356082778577134275778960917363717872146844090122495343014654958537105079227968925892354201995611212902196086403441815981362977477130996051870721134999999837297804995105973173281609631859502445945534690830264252230825334468503526193118817101000313783875288658753320838142061717766914730359825349042875546873115956286388235378759375195778185778053217122680661300192787661119590921642019893809525720106548586327886593615338182796823030195203530185296899577362259941389124972177528347913151557485724245415069595082953311686172785588907509838175463746493931925506040092770167113900984882401285836160356370766010471018194295559619894676783744944825537977472684710404753464620804668425906949129331367702898915210475216205696602405803815019351125338243003558764024749647326391419927260426992279678235478163600934172164121992458631503028618297455570674983850549458858692699569092721079750930295532116534498720275596023648066549911988183479775356636980742654252786255181841757467289097777279380008164706001614524919217321721477235014144197356854816136115735255213347574184946843852332390739414333454776241686251898356948556209921922218427255025425688767179049460165346680498862723279178608578438382796797668145410095388378636095068006422512520511739298489608412848862694560424196528502221066118630674427862203919494504712371378696095636437191728746776465757396241389086583264599581339047802759
which automatically increases precision until the error bound is met.
Back then i was planning to port this onto physical calculators like the
hp50g, but i decided i didn't need silly accuracy but only enough.
However, i've always been tantalised by the idea of applying the same approach
to solving once and for all the calculator problems of solve and
integrate. The problem of bounding the error with classical algorithms fails
because they are all based on sampling.
A rigorous numerical approach works for numerical quadrature by dynamically
creating a taylor expansion of your function (numerically) and essentially
integrating term by term, whilst keeping check on the overall error
bounds. it's like mixing numeric with symbolic - kind of semi-symbolic where
you only have to manipulate a series.
Anyhow, progress has been made in this area since i last looked. just
recently, i've been reading "Validated Numerics by Warwick Tucker." This is
quite a good introduction to the topic.
Edited: 15 Aug 2012, 8:28 p.m.
