Re: Transfering programs from HP 48G to HP 50G Message #2 Posted by Bart (UK) on 7 Aug 2012, 6:05 a.m., in response to message #1 by wildpig
If they are not in User RPL, then they probably won't work on the 50g.
If they are in User RPL, they *may* need some modification. Best option is to run them to the 50G and step through them (leftshift PROG, RUN, DBUG then SST), then check everything works as expected. See the AUR too: .HP 48gII and 50g Graphing Calculator Advanced User's Reference Manual (V2).
