Re: How to Install/Setup PC to HP41CL Serial Transfer Software? Message #3 Posted by Raymond Wiker on 6 Aug 2012, 6:14 a.m., in response to message #1 by Michael Lopez
I think you're making this more difficult than it needs to be :-)
What you should do is to save the source files (CLReader.cs and CLWriter.cs) to the directory that you want to run the utilities from, open a CMD prompt, chdir to the directory that you saved from, and run csc from there. That should give you CLReader.exe and CLWriter.exe, in that directory. After that, you can move the exe files if you want to.
So, if you have a directory c:\CLStuff, the sequence of operations is
1) Copy CLReader.cs and CLWriter.cs to this directory
2) Open a CMD window
3) In the command window, type
cd /d C:\CLStuff
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\csc.exe /t:exe CLReader.cs
C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\csc.exe /t:exe CLWriter.cs
You should then have CLReader.exe and CLWriter.exe in the directory C:\CLStuff
