Re: Bug in WP34S? Message #3 Posted by Namir on 5 Aug 2012, 6:01 p.m., in response to message #2 by Walter B
Walter,
Here is an example. The 41-style code that works is:
RCL 22
RCL 11
x<=? Y
GTO 15
When memory register 11 has a value less than or equal to the value in memory register 22, the program executes the GTO 15 command.
When I translated it to:
RCL 11
x<=?-> 22
GTO 15
It won't work. The program ignores GTO 15 and moves on to the next commands. Am I using the new test in reverse? Should it be?
RCL 22
x<=?-> 11
GTO 15
This "bug" appeared in several places in the program. When I translated the new stack-to-register tests to equivalent X/Y stack registers tests, the program worked.
I would like to use the new WP34S features. My hope is that the WP34S program in question can make it to the web-based HP Solve newsletter.
Namir
Edited: 5 Aug 2012, 6:10 p.m.
