Yet another Normal quantile function for the 34s Message #1 Posted by Dieter on 2 Aug 2012, 4:39 p.m.
As announced a few hours ago, here is my current (experimental ;-)) version of a 34s user code program for the Normal distribution's quantile function (QF); i.e. enter a probability p and get the corresponding z-value for which the Normal integral from -infinity to z equals p.
Yes, the 34s (of course) provides such a function (Phi-1 on g-shift 4), which has undergone many changes since its first implementation. The last version I used (3.1 3208) still has some issues with arguments very close to (but less than) 0.5 and very close to 1. It does not provide the accuracy level that might be possible. Results are fine in SP mode, but in double precision there is some room for improvement.
The following program works quite straightforward. First, it evaluates an initial estimate for the quantile:
let q = min(p, 1-p)
then, for q > 0.23
u = (0.5 - q) * sqrt(2 * pi)
z = u + u3/6
else
u = -2 * ln(q)
z = sqrt(-2 * ln(q * sqrt(2 * pi * (u - 1)))) + 0.254/u
Then this estimate is improved by the method suggested in A&S, p. 954:
t = (upperCDF(z) - q) / PDF(z)
z = z + t + t2*z/2 + t3*(2z+1)/6
Finally the sign of z is adjusted: for p >= 0.5 return z, else -z.
Now there is a pitfall in the evaluation of t. For z less than 1 and, more important, close to zero, the difference between CDF(z) and q may lose a more or less substantial number of digits. This problem can be solved if the Normal integral from 0 to z is evaluated, i.e. CDF(z) - 0.5. The 34s does not provide such a function, but there is a simple workaround:
CDF(z) - 0.5 = 1/2 Incomplete_regularized_Gamma_p(1/2, z2/2)
The desired difference then simply is (0.5 - q) minus this. The program uses this method for z =< 0.5. Switching at z = 1 should also be fine.
When evaluated with sufficient precision (I did some tests in a 38-digit environment), two successive correction steps should provide a result with a max. error of approx. 5 units in the 35th significant digit (5D35), i.e. at the limit of what can be done in double precision.
For z < 4E-9 the error of the initial estimate is less than 6D36, so no further correction is required, and z < 0.04 is so close that just one correction step keeps the error near 2D35 or below. At least when evaluated in 39-digit precision. ;-)
If the correction method is expanded with a fourth term, the error can even be pushed down to somewhere in the 40th digit. Which may be an option if the algorithm is adopted for an internal function with 39-digit precision. In this case the threshold values mentioned in the previous paragraph should be changed to 2E-10 resp. 0.02.
Provided the CDF resp. IGamma functions have all their 34 digits correct, the accuracy on a 34s in DP mode should be 33 digits. I did not do any extensive tests, so beware and see yourself what you get. According to my results, z > 1 usually is either exact or sometimes 1 ULP off. For z < 1 the last digit may be off by several units (I did not notice more than 3).
And finally: here's the code.
0001 *LBL'QF'
0002 CF 00
0003 SF 01
0004 ENTER[^]
0005 +/-
0006 INC X
0007 MIN
0008 STO 01 // q = min(p, 1-p)
0009 x[!=]? L
0010 SF 00 // Set Flag 0 if p < 0.5 (i.e. 1-p != q)
0011 .
0012 5 // pre-store 0.5 in R00 for later use
0013 STO 00
0014 # 023
0015 SDR 002
0016 RCL 01
0017 x>? Y
0018 GTO 01
0019 ENTER[^] // tail estimate
0020 LN
0021 STO+ X
0022 +/-
0023 STO Z
0024 DEC X
0025 # [pi]
0026 [times]
0027 STO+ X
0028 [sqrt]
0029 x
0030 LN
0031 STO+ X
0032 +/-
0033 [sqrt]
0034 # 254
0035 SDR 003
0036 RCL/ Z
0037 +
0038 STO 02
0039 GTO 02
0040 *LBL 01 // estimate for central region
0041 RCL 00
0042 RCL- Y
0043 # [pi]
0044 STO+ X
0045 [sqrt]
0046 [times]
0047 ENTER[^]
0048 x[^3]
0049 # 006
0050 /
0051 +
0052 STO 02
0053 # 004
0054 SDR 002
0055 x>? Y
0056 CF 01 // z < 0.04 requires just one correction step
0057 SDR 007
0058 x>? Y
0059 GTO 03 // z < 4E-9 needs no correction at all => exit
0060 *LBL 02
0061 RCL 02
0062 x>? 00 // "x>1?" should be fine either
0063 SKIP 009
0064 x[^2]
0065 RCL[times] 00
0066 RCL 00
0067 I[GAMMA][sub-p]
0068 RCL[times] 00
0069 RCL 00
0070 RCL- 01 // For q close to 0.5:
0071 RCL- Y // upperCDF(z) - q = (0.5-q) - IGamma_p(0.5, z2/2)
0072 SKIP 002
0073 [PHI][sub-u](x) // Otherwise evaluate Phi_u(z) - q directly
0074 RCL- 01
0075 RCL 02
0076 [phi](x)
0077 /
0078 FILL
0079 x[^3] // Apply a third-order correction
0080 RCL 02 // Evaluate all three terms individually
0081 x[^2] // and add them in order of their magnitude,
0082 STO+ X // smallest terms first, to preserve
0083 INC X // as much accuracy as possible
0084 [times]
0085 # 006
0086 /
0087 x[<->] Y
0088 x[^2]
0089 RCL[times] 02
0090 RCL[times] 00
0091 +
0092 +
0093 STO+ 02
0094 FS?C 01
0095 GTO 02
0096 *LBL 03
0097 RCL 02 // exit program
0098 FS?C 00 // set sign if required
0099 +/-
0100 END
Registers:
R00: 0.5
R01: q = min(p, 1-p)
R02: |z|
Flags:
F00: Set for p < 0.5, else clear
F01: Set if a second iteration is required, else clear
Still all I got is the 34s emulator. So I would appreciate some feedback from those who use a "real" hardware 34s. How fast does this program run? Switch to double precision (Mode menu, DBLON) and see how it performs. Do you find any errors that are larger than a few units in the last (34th) digit? Please note that this code has not been thoroughly tested - simply try it and see what you get. :-) I am sure there still is room for the one or other improvement. All suggestions are welcome.
Dieter
Edited: 2 Aug 2012, 6:11 p.m.
