A little OT: Blank date fields in 200LX database Message #1 Posted by Dave Britten on 12 July 2012, 2:28 p.m.
I'm making a 200LX database file for recording medications. One of the fields is "Discontinued", for recording the date which the medication is discontinued.
I'd like to make a subset (F6) that only shows records where that field is blank, i.e. still current.
According to this article, I should be able to use "!*Discontinued" as the SSL expression in order to look for a blank date field:
http://www.palmtoppaper.com/ptphtml/44/44c00013.htm
But when I do that, I just get all records again. The entire expression I'm using is exactly as follows:
!*Discontinued
Am I misunderstanding their explanation? Database tells me that I'm running version 1.1 - not sure if there are any other versions in different ROM revisions. Also, does anybody know where to find the GENERAL.GDB file referenced in that article? I was searching high and low, but couldn't find it.
