Curious SINPLOT behavior on HP71B Message #1 Posted by Christoph Giesselink on 11 July 2012, 2:56 p.m.
I'm somehow curious with the HP71B SINPLOT example
5 DEGREES @ PRINT CHR$(27);"E";
10 FOR X=1 TO 32 @ Y=SIN(X*16)*4+4
20 PRINT CHR$(27);"%";CHR$(X);CHR$(Y);"*";
30 NEXT X
published here some weeks ago. The difference to the published version is, that I restricted to the X loop to 32 that the curve will only printed once on a 82163 video interface.
During my tests with Emu71/Win and a Virtual IL HP-82163A video simulator (ILVideo) I recognized sometimes garbage in the sineplot output. I analyzed the IL frame traffic and found "DAB 0D DAB 0A" data packages in the framing. So the garbage is created when the CR LF data frames are inside the cursor position ESC sequence like
DAB 1B DAB 25 DAB 12 DAB 0D DAB 0A DAB 00 DAB 2A
Because the CR LF are in the IL framing data I was sure that my HP-82163A video simulator was working correctly. So the next suspect was the Emu71/Win emulator with it's HPIL processor simulation. But had no idea how to check this, so I decided to use a real HP71B (ROM rev. 1BBBB) instead of Emu71/Win.
So my loop now looked like
HP71B -> PILBOX | real HP-IL world
ILPilbox -> ILScope -> ILVideo -> back to ILPilbox | virtual HP-IL world
I got the same randomly garbage in the sineplot output and found also "DAB 0D DAB 0A" data packages in the ILScope output window. So IMHO the BASIC program itself is buggy. I tried to disable the "DAB 0D DAB 0A" data with the "WIDTH INF" command, but no success.
Any other idea?
Christoph
