Re: [41CL] Alternative serial connector, saving a port Message #21 Posted by aurelio on 4 July 2012, 2:22 p.m., in response to message #1 by Kerem Kapkin (Silicon Valley, CA)
Hi Kerem, Hi all!
Compliments for your job first of all
Actually I thought, before to order the connector already plugged in the rom slot cover, toghether with the CL board, to this solution (the charger connector slot I mean, not ofcourse to your personal engeneering job), in way to keep one more port free, but then before to write to Monte I changed my mind:
I think infact that it's better to keep the charger port free, expecially with the 41CL which requires more power than the others...and for this reason, I think, it should be reccomended the use of a battery pack in place of the more used alkaline cells holder, what do you think about?
Edited: 4 July 2012, 4:06 p.m. after one or more responses were posted
