SR-52 flaky display Message #1 Posted by Colin Verrilli on 1 July 2012, 11:37 p.m.
Hello All,
Please excuse the OT post but not sure where else to go.
I have an SR-52 that I got new in '76 (as a freshman in high school) that I'm trying to resurrect.
Besides the gummy wheel problem, it has a problem with the digits. I haven't characterized it exactly, but here are some things I notice:
- when I have the degree / radian switch on radians, I can not enter any digits.
- when I have the switch on degrees, I can enter all digits and the display seems to work fine.
- I can do operations on numbers that do not contain 8's or 9's<nl>
- whenever I enter a number with an 8 or 9 and then press an operation key, the display flakes out
- also if I do some math on smaller numbers and the answer contains an 8 or 9 the display flakes out
- flaky display adds a bunch of 8's before the number and / or adds some digits after the decimal point. Sometimes there are gaps between digits.
- The flakiness seems to be not just at the display, but also in the operand registers of the processor since I can not undo the display mistake by doing the reverse math operation.
- happens both on battery power and with charger
Wondering if anyone has any experience with problems like this or any ideas.
Thanks,
Colin
Apex, NC
