HP Forum Archive 21
Cubic Formula: HP 71B
Message #1 Posted by Eddie W. Shore on 30 June 2012, 4:34 p.m.
Calculator Blog
(Updated 7/1/12 - thanks everyone!)
Edited: 1 July 2012, 4:49 p.m. after one or more responses were posted
Re: Cubic Formula: HP 71B
Message #2 Posted by Diego Diaz. on 1 July 2012, 12:22 p.m.,
in response to message #1 by Eddie W. Shore
Hi Eddie,
Thanks for sharing this interesting approach.
Just for sake of precision, in your program listing, line 36 seems truncated and merged with line 38; and line 54 can be removed.
Hope this helps.
Best wishes.
Diego.
Message #3 Posted by Gerson W. Barbosa on 1 July 2012, 2:17 p.m.,
in response to message #2 by Diego Diaz.
Also, there's a typo in line 30. It should be
30 P = 2*B^3 - 9*A*B*C + 27*A^2*D.
If line 36 is changed to
36 IF A1 < 0 THEN 48
it will work for his first and last examples. Assuming line 36 is correct, there's still one typo left because of the byte count (547 bytes instead of 549). There is another typo in X1 in the second example (an extra zero between 4 and 6). This will be a nice program to convert to RPN when Eddie fixes the typos.
Gerson.
Message #4 Posted by Eddie W. Shore on 1 July 2012, 4:44 p.m.,
in response to message #3 by Gerson W. Barbosa
Gerson.
Diego and Gerson: Thank you so much. I made the corrections. In addition to deleting line 54, I also deleted line 100. I also had to make corrections on one of the examples.
The program is now 533 bytes.
The link on the original post is updated. I appreciate that you pointed my errors to me. :)
Message #5 Posted by Gerson W. Barbosa on 1 July 2012, 6:51 p.m.,
in response to message #4 by Eddie W. Shore
Eddie,
Would you please double-check the lines 48, 50 and 52? It still doesn't work when A1<0 (your second and fourth examples). Two bytes are still missing. X1 in the second example should be -3.46050487001, not -3.406050487001.
Thank you,
Gerson.
Message #6 Posted by Eddie W. Shore on 2 July 2012, 8:03 a.m.,
in response to message #5 by Gerson W. Barbosa
For Example 2 A = 1,
B = 4,
C = 1,
D = -3
I get:
P = 11
Q = 13
A1 = -2166.75
For Example 4
A = 1
B = -2
C = -5
D = 6
I get:
P = 56
Q = 19
A1 = -6075
Does this help?
Edited: 2 July 2012, 8:54 a.m.
Message #7 Posted by Eddie W. Shore on 2 July 2012, 9:07 a.m.,
Eddie,
Thank you,
Gerson.
Line 52 should be
52 X1 = -B/(3*A) - 2/(3*A) * (P1^(1/3)*COS(P2/3))
On a separate note, I edited line 68 to:
68 IF K>=0 THEN 70 ELSE 90
This corrects the display for repeated roots (Example 5)
I edited the blog too.
Edited: 2 July 2012, 9:40 a.m.
Message #8 Posted by Gerson W. Barbosa on 2 July 2012, 12:57 p.m.,
in response to message #7 by Eddie W. Shore
Hello Eddie,
Thanks for the program! The algorithm will be perfect for calculators that don't have native complex numbers. Thanks also for your prompt fixing of the typos. All examples work fine now:
>RUN
CUBIC
A,B,C,D 3,3,-3,6
X1=-1.99999999999
REAL= .499999999995
IMAG= .866025403772
>RUN CUBIC A,B,C,D 1,4,1,-3 X1=-3.46050487001 X2= .699628148275 X3=-1.23912327826
>RUN CUBIC A,B,C,D -2,0,-1,5 X1= 1.23477282504 REAL=-.61738641252 IMAG=-1.28198983892
>RUN CUBIC A,B,C,D 1,-2,-5,6 X1=-1.99999999999 X2= 3 X3= .999999999985
>RUN CUBIC A,B,C,D 1,-3,3,-1 X1= 1 X2= 1 X3= 1
Have you considered using Jean-François Garnier's Emu71 emulator? You can avoid typing errors by editing your program on the emulator and copying the program lines from the DOS windows and pasting them to your text editor (I think this should be possible also on Christoph Giesselink's HP71B Emulator).
Since there is no line between lines 68 and 70, you can save a few bytes by rewriting line 68 as
68 IF K<0 THEN 90
Best regards,
Gerson.
Message #9 Posted by Eddie W. Shore on 3 July 2012, 11:14 p.m.,
in response to message #8 by Gerson W. Barbosa
I like emulators, but for me, there is nothing like operating on the real thing.
