Re: [OT] Powering the 41CL ... Message #3 Posted by Matt Kernal on 30 June 2012, 6:17 p.m., in response to message #2 by Ángel Martin
Sorry for changing the topic, but this thread has both of the Users, Gene and Angel, that have commented on different ways of powering the CL41. So here are my questions:
How *bad* (or good?) really is the power usage of the CL, concerning the CL's 110 microamp standby current draw compared to the original's 10 microamp draw? I realize it's a subjective question, but how much time can you get/go until the BAT annunciator comes on?
Gene: Can you provide info on the rechargeable N-cell batteries and charger that you're using? I'm curious of the brand/model, time between charges, and any pros and cons you've discovered. Thanks.
Angel: I like the idea of the 5 volt power you apply through a sacrificial module - utilizing the housing and it's terminals to power the CL through an unused port. I assume you have also have batteries in the calculator when your power adapter is plugged in, so are they rechargeable, or regular alkalines? I assume they are rechargeables. Can you elaborate on the batteries you're using and what module (a *common* Memory module?) you used to make up the power connection?
Thanks guys - and anyone else is invited to comment. Again, I apologize for changing the topic.
Matt
Edited: 30 June 2012, 6:20 p.m.
